Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner. Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
  • Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
  • Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
  • Start the engine
Use una llave de cubo de 3/8 para aflojar los pernos de retención en el filtro de aire.
Gire el filtro de aire para que las gargantas de ambos carburadores estén limpias. Ahora podrás ajustarlos.
Encender el motor
