Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 12
Use a flat blade screwdriver to 'walk' each of the two brass brush housings away from the motor shaft. After the brass brush housings are separated from their housing, the brush spade connectors simply slide out. After the brass brush housings are separated from their housing, the brush spade connectors simply slide out.
  • Use a flat blade screwdriver to 'walk' each of the two brass brush housings away from the motor shaft.
  • After the brass brush housings are separated from their housing, the brush spade connectors simply slide out.
Insertar traducción aquí
