Saltar al contenido principal
Inglés
Español
Paso 4
Align the breaker plate with the distributor body and screw it into place. Attach the other side of the grounding strap to the breaker plate hold-down screw as shown.
  • Align the breaker plate with the distributor body and screw it into place.
  • Attach the other side of the grounding strap to the breaker plate hold-down screw as shown.
  • Slide the magnetic sleeve onto the distributor shaft. Make sure that it is pressed firmly in place.
  • Using the provided plastic feeler gauge, or a 0.030" feeler gauge, set the gap between the ignition unit and the magnetic sleeve.
  • While holding the ignition unit in place tighten the two locking nuts.
Insertar traducción aquí
