Saltar al contenido principal
Inglés
Español
Paso 2
Remove the two screws holding down the distributor cap, by using a flat head screwdriver, and remove the cap, but do not disconnect the spark plug wires. Disconnect the wire that goes from the coil to the distributor at the negative terminal of the coil.
  • Remove the two screws holding down the distributor cap, by using a flat head screwdriver, and remove the cap, but do not disconnect the spark plug wires.
  • Disconnect the wire that goes from the coil to the distributor at the negative terminal of the coil.
  • Carefully pull the rotor off the distributor shaft.
  • Remove the two screws holding down the breaker plate and pull off the entire breaker plate/points assembly.
Insertar traducción aquí
