Saltar al contenido principal
Inglés
Español
Paso 10
A series of screws and tightly wrapped antenna cables secure the rear I/O panel shield to the logic board. A few twists of our precision aluminum driver with a T6 Torx bit and some cable de-routing is all it takes to remove the shield. A few twists of our precision aluminum driver with a T6 Torx bit and some cable de-routing is all it takes to remove the shield.
  • A series of screws and tightly wrapped antenna cables secure the rear I/O panel shield to the logic board.
  • A few twists of our precision aluminum driver with a T6 Torx bit and some cable de-routing is all it takes to remove the shield.
Una serie de tornillos y cables de antena bien ajustados aseguran el blindaje del panel de E / S posterior a la placa lógica.
Con solo girar un destornillador de aluminio de precisión con una broca Torx T6 y un poco de desenredo del cable, es necesario quitar la protección.
