Saltar al contenido principal
Inglés
Español
Paso 11
The motherboard has absorbed yesteryear's daughterboard, leaving a modular USB-C port (with a Knowles hanger-on microphone) ripe for the picking. Samsung continues to provide sanctuary for the now endangered headphone jack, while saddling it with a super thin spring-contact-connected cable. The heat pipe has significantly more surface area than prior generations. Perhaps those pipes proved the concept, or proved they needed to be that much beefier (because Fortnite).
  • The motherboard has absorbed yesteryear's daughterboard, leaving a modular USB-C port (with a Knowles hanger-on microphone) ripe for the picking.
  • Samsung continues to provide sanctuary for the now endangered headphone jack, while saddling it with a super thin spring-contact-connected cable.
  • The heat pipe has significantly more surface area than prior generations. Perhaps those pipes proved the concept, or proved they needed to be that much beefier (because Fortnite).
La placa madre ha absorbido la placa hija de antes, dejando un puerto modular USB-C (con micrófono colgante) listo para ser levantado.
Samsung continúa proporcionando santuario para la toma de auricular que ahora está en peligro de extinción al mismo tiempo que la endosa con un cable conectado de contacto de muelle muy fino.
El tubo termosifón bifásico tiene bastante más superficie que el de generaciones previas. Quizá estos tubos demostró el concepto o demostró que debían ser más fornidos (debido a Fornite).
-[* black] The motherboard has absorbed yesteryear's daughterboard, leaving a modular USB-C port (with hanger-on microphone) ripe for the picking.
+[* black] The motherboard has absorbed yesteryear's daughterboard, leaving a modular USB-C port (with a Knowles hanger-on microphone) ripe for the picking.
[* black] Samsung continues to provide sanctuary for the now endangered headphone jack, while saddling it with a super thin spring-contact-connected cable.
[* black] The heat pipe has significantly more surface area than [guide|66389|prior generations|stepid=135836|new_window=true]. Perhaps those pipes proved the concept, or proved they needed to be that much beefier (because Fortnite).
