Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
The EMI filter is connected by three screws. Use the T10 screwdriver to remove them. The screw that holds in both the filter and a wire that is connected to it is a different size and should be kept identifiable from the other two screws. The green and yellow wire that was held in by the different screw is tucked behind another component. To get it out, squeeze it behind the black wire and the filter will be able to be removed from the casing.
  • The EMI filter is connected by three screws. Use the T10 screwdriver to remove them.
  • The screw that holds in both the filter and a wire that is connected to it is a different size and should be kept identifiable from the other two screws.
  • The green and yellow wire that was held in by the different screw is tucked behind another component. To get it out, squeeze it behind the black wire and the filter will be able to be removed from the casing.
Insertar traducción aquí
