Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Paso 17
It was a slow and tedious process, but we removed the battery—sans puncture. The task took us roughly 15 minutes to complete, without the use of a heat gun. All we needed was a Torx screwdriver and three spudgers. In contrast, it took us three attempts to successfully remove the 15" Retina's battery without puncturing it, and the third attempt took over half an hour to perform.
  • It was a slow and tedious process, but we removed the battery—sans puncture.
  • The task took us roughly 15 minutes to complete, without the use of a heat gun. All we needed was a Torx screwdriver and three spudgers.
  • In contrast, it took us three attempts to successfully remove the 15" Retina's battery without puncturing it, and the third attempt took over half an hour to perform.
  • Yet, EPEAT lab investigators reported the time required for the MacBook Pro 15" Retina battery removal was under 2.5 minutes, cited that the operation could be conducted “easily and safely,” and gave the laptop its Gold rating.
  • We certainly disagreed with that notion, given it was the least repairable computer we've ever encountered.
  • The 13" Retina battery is a step in the right direction towards recyclability and repairability, but it's still a far cry from the no-adhesive MacBook Pro batteries of yesteryear.
Fue un proceso lento y tedioso, pero removimos la batería —sin perforarla.
La tarea nos llevó unos 15 minutos, sin el uso de una pistola de aire caliente. Todo lo que necesitábamos era un destornillador Torx y tres spudgers.
Por el contrario, nos llevó tres intentos para remover con éxito la batería de Retina de 15" sin perforarla, y el tercer intento nos llevó más de media hora.
Sin embargo, los investigadores de laboratorio EPEAT informaron que el tiempo requerido para remover la batería de Macbook Pro 15" Retina era de menos de 2.5 minutos, citando que la operación podía se conducida de forma “fácil y segura,” y le dio a la laptop su calificación de oro.
No estamos de acuerdo con esta noción, dado que fue la computadora menos reparable que hemos encontrado.
La batería de Retina 13" es un paso en la dirección correcta hacia la reciclabilidad y reparabilidad, pero aun está a años luz de las baterías no adhesivas de MacBook Pro de años anteriores.
