Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
Inside the headband, we note a Class 1 Laser label. It might seem like a scary thing to find on your eyewear, but it's safe for all normal use conditions and likely no more dangerous than a CD player. Twirling away the standard Torx screws and removing the panel reveals the first of two speakers, wired via spring contacts, and protected by color-coded gaskets—great repairability so far! Also hiding under those panels: the two upper ends of the device's single built-in cable—and a few of the magnetic bits that help adjust the fit.
  • Inside the headband, we note a Class 1 Laser label. It might seem like a scary thing to find on your eyewear, but it's safe for all normal use conditions and likely no more dangerous than a CD player.
  • Twirling away the standard Torx screws and removing the panel reveals the first of two speakers, wired via spring contacts, and protected by color-coded gaskets—great repairability so far!
  • Also hiding under those panels: the two upper ends of the device's single built-in cable—and a few of the magnetic bits that help adjust the fit.
  • But what's that odd little black box protruding from the right side of the headband?
Dentro de la diadema, observamos una etiqueta láser de Clase 1. Puede parecer una cosa aterradora para encontrar en sus gafas, pero es seguro para todas las condiciones de uso normales y probablemente no sea más peligroso que un reproductor de CD.
Girando los tornillos Torx estándar y retirando el panel, aparece el primero de los dos altavoces, cableados a través de contactos de resorte, y protegidos por empaques codificados por color.
También se esconden debajo de esos paneles: los dos extremos superiores del único cable incorporado del dispositivo, y algunos de los bits magnéticos que ayudan a ajustar el ajuste.
Pero, ¿qué es esa extraña caja negra que sobresale del lado derecho de la diadema?
