Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 18
We ignore the modular headphone jack and button board, in favor of that shield-filled field of silicon. A PC favorite Cooler Master fan graces this PCB, explaining those vents we saw earlier. Twirling away screws isn't enough to free the heat sink, which is very stubbornly glued in place. After a good ten minutes of heating and prying, it finally loosens its conductive grip.
  • We ignore the modular headphone jack and button board, in favor of that shield-filled field of silicon.
  • A PC favorite Cooler Master fan graces this PCB, explaining those vents we saw earlier.
  • Twirling away screws isn't enough to free the heat sink, which is very stubbornly glued in place. After a good ten minutes of heating and prying, it finally loosens its conductive grip.
  • This is a lot of cooling for a small, wearable device, but it makes sense given the job it has to do. There's a lot of heat-generating silicon in there—and in this case hot pockets are a bad thing.
Ignoramos el conector modular para auriculares y el panel de botones, en favor de ese campo de silicio lleno de escudo.
Un fan de Cooler Master favorito de la PC agracia a esta PCB, explicando las ventilaciones que vimos anteriormente.
Girar los tornillos no es suficiente para liberar el disipador de calor, que está muy pegado en su lugar. Después de unos diez minutos de calentamiento y palanca, finalmente afloja su agarre conductor.
Esto es mucho enfriamiento para un dispositivo pequeño y portátil, pero tiene sentido dado el trabajo que tiene que hacer. Hay una gran cantidad de silicio que genera calor allí, y en este caso, los bolsillos calientes son una mala cosa.
