Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 5
When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover. Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend. Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
  • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
  • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
  • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
Cuando el adhesivo ha sido separado apropiadamente en tres lados podrás levantar lentamente la cubierta trasera.
No fuerces la apertura. Utilice un iOpener nuevamente para suavizar el adhesivo si la cubierta trasera no se desprende o empieza a doblarse.
Presta atención al conector del sensor de la huella dactilar al abrir la cubierta trasera. Necesitarás desconectarlo como se describe en el siguiente paso.
