Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Lift up and loosen the metallic silver trim on the perimeter of the phone using a nylon spudger. Carefully remove the gray mid-plate with the spudger. Take extra caution to not destroy the QWERTY keyboard, which lies directly behind the mid-plate.  Do not slide open the phone at this time.
  • Lift up and loosen the metallic silver trim on the perimeter of the phone using a nylon spudger.
  • Carefully remove the gray mid-plate with the spudger.
  • Take extra caution to not destroy the QWERTY keyboard, which lies directly behind the mid-plate. Do not slide open the phone at this time.
  • The mid-plate should be completely removed from the keyboard and separated from the device.
  • At this point, you may remove the original QWERTY keyboard and install a replacement keyboard. Installation is the reverse of removal.
Insertar traducción aquí
