Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 4
Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm). As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel. Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
  • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
  • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
  • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
Con cuidado desliza la punta de la púa de apertura a lo largo del borde del teléfono, asegúrate de no cortar más de 1.5 mm.
Mientras deslizas la púa por el borde, sentirás la punta de la púa presionarse contra el borde del panel OLED. Hasta allí es donde llega la púa sin dañar el panel.
Una vez que hayas separado el adhesivo, deja una púa de apertura en el borde para evitar que el adhesivo se vuelva a sellar.
