Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 22 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use the point of a spudger to pry the lower display connector out of its socket. To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
Disconnect the display and digitizer
  • Use the point of a spudger to pry the lower display connector out of its socket.
  • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
Utiliza el punto de un spudger para levantar el conector inferior de pantalla del su cuenca.
Para volver a sujetar conectores a presión como este, presiona sobre un lado hasta que haga clic, luego repite en el otro lado. No presiones en el medio. Si el conecto está ligeramente desalineado, el conector puede doblarse y causar daño permanente.
[title] Disconnect the display and digitizer
[* black] Use the point of a spudger to pry the lower display connector out of its socket.
[* icon_reminder] To re-attach [guide|25629|press connectors|stepid=70308|new_window=true] like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
