Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 24 guías que incluyan este paso.
Inglés
Español
Paso 2
Apply a suction cup to the lower half of the front panel, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
Separate the display
  • Apply a suction cup to the lower half of the front panel, just above the home button.
  • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
Aplica una ventosa en la mitad inferior del panel frontal, justo encima del botón de inicio.
Asegúrate de que la ventosa no se superponga con el botón de inicio, ya que esto evitará que se forme un sello entre la ventosa y el cristal frontal.
[title] Separate the display
[* black] Apply a suction cup to the lower half of the front panel, just above the home button.
[* icon_note] Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
[* icon_note] If your display is badly cracked, [guide|103486|covering it with a layer of clear packing tape|new_window=true] may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
