Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
We disconnect the battery without any drama—it's buttoned down with a T5 Torx screw, so we use one of our blue and black Pro Tech specialty drivers to dispatch it. At 58.0 Wh, this battery has gotten a significant boost over the 49.2 Wh unit we found in our original 13" Touch Bar teardown. Turns out that extra 'oomph' comes from  a slightly bigger battery—arrayed into six cells this time, instead of five. It's also heavier, weighing in at in at 232.7 g, versus the old battery's 196.7 g.
  • We disconnect the battery without any drama—it's buttoned down with a T5 Torx screw, so we use one of our blue and black Pro Tech specialty drivers to dispatch it.
  • At 58.0 Wh, this battery has gotten a significant boost over the 49.2 Wh unit we found in our original 13" Touch Bar teardown.
  • Turns out that extra 'oomph' comes from a slightly bigger battery—arrayed into six cells this time, instead of five. It's also heavier, weighing in at in at 232.7 g, versus the old battery's 196.7 g.
  • And yet this MacBook Pro's total weight hasn't changed one iota. We're not sure which parts of this device have been on a diet, but it does look like Apple shaved some mass off the top case.
  • Despite all that, Apple still rates battery life the same as the prior model. Those extra processor cores don't come for free.
  • The new-and-improved speakers (on the right) have grown, too—they're longer and narrower, filling all the remaining space, and bumping right up against the logic board thanks to the revised top case design.
Desconectamos la batería sin ningún drama—está abotonada con un tornillo T5 Torx, así que usamos uno de nuestros destornilladores azul y negro especiales de Pro Tech para despacharla.
Con 58.0 Wh, esta batería ha recibido un impulso significativo sobre la unidad de 49.2 Wh que encontramos en nuestro desmontaje original de 13 "Touch Bar.
Resulta que el impulso proviene de una batería un poco más grande, dispuesta en seis celdas esta vez, en lugar de cinco. También es más pesada, con un peso de 232,7 g, frente a los 196,7 g de la batería anterior.
Y, sin embargo, el peso total de este MacBook Pro no ha cambiado ni un ápice. No estamos seguros sobre qué partes de este dispositivo han estado a dieta, pero parece que Apple sacó algo de masa de la carcasa superior.
A pesar de todo esto, Apple asegura que la duración de la batería es igual a la del modelo previo. Estos núcleos del procesador no vienen gratis.
Los nuevos y mejorados altavoces (a la derecha) también han crecido, son más largos y angostos, llenando todo el espacio restante y chocando contra la placa lógica gracias al diseño revisado de la cubierta superior.
