Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 3
Use an opening pick to gently separate the adhered portion of the antenna flex cable from the top surface of the speaker. This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This makes it easier to separate (and re-adhere) the flex cable safely. This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This makes it easier to separate (and re-adhere) the flex cable safely.
  • Use an opening pick to gently separate the adhered portion of the antenna flex cable from the top surface of the speaker.
  • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This makes it easier to separate (and re-adhere) the flex cable safely.
Utiliza una púa de apertura para separar con cuidado la porción adherida del cable flexible de la antena desde la superficie superior del altavoz.
Esta porción del cable flexible está adherida en su lugar. Si es necesario, aplica un poco de calor de un iOpener o secador de pelo para ablandar el adhesivo. Esto hace que sea más fácil de separar ( y volver a adherir) el cable flexible de forma segura.
