Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive. Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
  • Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
  • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. Do not deform or damage the battery.
  • To protect your fingers, wear gloves or wrap the string ends around a tool (such as the two screwdriver handles shown in the image).
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
Si cualquiera de las tiras adhesivas se rompió y la batería sigue pegada a la caja trasera, prepara el iOpener o usa un secador de pelo y aplícalo sobre la caja trasera, directamente detrás la batería. Esto ayudará a ablandar el adhesivo.
Calienta el iPhone hasta que la caja trasera está ligeramente demasiado caliente al tacto. No sobrecalientes el iPhone o la batería podría prenderse fuego.
Da vuelta el iPhone y pasa un trozo de hilo (como hilo dental o una cuerda fina de guitarra) por debajo de la batería.
Jala el hilo de lado a lado como una sierra a lo largo de la batería para separar el adhesivo. No deformes o dañes la batería.
Para proteger tus dedos, usa guantes o envuelve los extremos del hilo alrededor de una herramienta (como los dos mangos de destornillador que se muestran en la imagen).
Si eliges usar unas herramientas de palanca para levantar la batería del iPhone, ten precaución o podrías dañar los cables planos o la bobina de carga inalámbrica directamente por debajo de la batería.
