Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device.
  • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device.
  • We used two iOpeners to open up the tablet. The process is doable with a single iOpener, but would take substantially longer. Alternatively, you can use a heat gun to quickly loosen the adhesive.
  • Leave the iOpener on edge for two minutes.
  • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
Insertar traducción aquí
