Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 29
Paso 29
Lift and remove the battery. Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
  • Lift and remove the battery.
  • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
  • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
  • Otherwise, soak each strip of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with a plastic tool. This can take quite a bit of work, so be patient.
  • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
  • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
  • Calibrate your battery before using it: allow it to drain overnight, then charge it to 100% and drain it again until your MacBook Pro shuts down automatically. Charge it again and use it normally.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
Insertar traducción aquí
