Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Insert an opening pick between the trackpad ribbon cable and the battery. Carefully slide your pick underneath the length of the ribbon cable to separate the adhesive securing it to the battery. The ribbon cable is easily damaged. If necessary, use a little heat from an iOpener or hair dryer to soften the adhesive so you can remove it with less force.
  • Insert an opening pick between the trackpad ribbon cable and the battery.
  • Carefully slide your pick underneath the length of the ribbon cable to separate the adhesive securing it to the battery.
  • The ribbon cable is easily damaged. If necessary, use a little heat from an iOpener or hair dryer to soften the adhesive so you can remove it with less force.
Insertar traducción aquí
