Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Inglés
Español
Paso 3
Lift the logic board EMI shield, starting at the edge nearest the top of the iPad. Slowly peel the EMI shield up from the logic board. This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
  • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
  • Slowly peel the EMI shield up from the logic board.
  • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
  • Remove the logic board EMI shield.
Insertar traducción aquí
