Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 28
As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case. Carefully insert an opening pick under the logic board, between the front-facing camera and the battery. Be sure to insert the pick over the the antenna cable that runs along the length of the battery.
  • As you complete the next few steps, prying adhesive securing the logic board in place, always start by testing gently to see if the adhesive is softened. If not, reheat the iOpener and reapply it to the back of the rear case.
  • Carefully insert an opening pick under the logic board, between the front-facing camera and the battery.
  • Be sure to insert the pick over the the antenna cable that runs along the length of the battery.
  • Slide the guitar pick toward the front-facing camera connector, and stop at the bend in the logic board.
Insertar traducción aquí
