Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Traduciendo paso 4
Paso 4
Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
[* red] Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board. |
[* icon_note] To reduce the risk of a short, you can use a battery isolation pick to [* icon_caution] The battery isolation pick or battery blocker is an outdated way of isolating the battery, as you risk damaging the battery pins underneath the logic board. If you use this method, take extreme care to insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side. |
[* black] Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work. |
