Saltar al contenido principal
Inglés
Español
Paso 8
Gently slide an opening pick under the top edge of the display to separate the adhesive underneath. Only insert the pick about 0.25 inches (6 mm) under the display.
  • Gently slide an opening pick under the top edge of the display to separate the adhesive underneath.
  • Only insert the pick about 0.25 inches (6 mm) under the display.
  • Don't pry too aggressively or you may damage the front-facing sensors and speaker assembly. You can come back to finish separating this section after the rest of the display is loose.
Insertar traducción aquí
