Saltar al contenido principal
Inglés
Español
Paso 2
Once the screen is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can. If your display is badly cracked, the suction cup may not stick. Try lifting the display with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed. Lift on the suction cup, and insert an opening pick under the display assembly.
  • Once the screen is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can.
  • If your display is badly cracked, the suction cup may not stick. Try lifting the display with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  • Lift on the suction cup, and insert an opening pick under the display assembly.
Insertar traducción aquí
