Saltar al contenido principal
Inglés
Español
Traduciendo paso 4
Paso 4
When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature. Power on your Mac and launch Terminal. Copy and paste the following command (or type it exactly) into Terminal:
  • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
  • Power on your Mac and launch Terminal.
  • Copy and paste the following command (or type it exactly) into Terminal:
  • sudo nvram AutoBoot=%03
  • Press [return].
  • If you are prompted for an administrative password, type the password and press [return].
  • Your password will not be displayed in Terminal.
  • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
Cuando tu reparación es completada y tu Mac es re-ensamblada exitosamente, puedes re-habilitar la función de Auto Encendido.
Enciende tu Mac y lanza el Terminal.
Copia y pega el siguiente comando (o estribillo exactamente) en el Terminal:
Presiona [Return].
Si la contraseña administrativa es solicitada, escribe la contraseña y presiona [Return].
Tu contraseña no será mostrada en el Terminal.
Alternativamente, puedes reiniciar la NVRAM de tu Mac para re-habilitar el Auto Encendido.
