Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 5
We pop off a nice red bracket to free that lengthy fingerprint sensor cable, and spy the NFC antenna OnePlus so graciously pointed out. Prior OnePlus antennas did just fine without a glass back (which isn't even for wireless charging). So this glass seems to be mainly just for looks. And cracking. The friendly green tab on this relatively accessible battery says, "由此拉起可拆出电池". This translates to "Pull up and out to remove the battery."
  • We pop off a nice red bracket to free that lengthy fingerprint sensor cable, and spy the NFC antenna OnePlus so graciously pointed out.
  • Prior OnePlus antennas did just fine without a glass back (which isn't even for wireless charging). So this glass seems to be mainly just for looks. And cracking.
  • The friendly green tab on this relatively accessible battery says, "由此拉起可拆出电池". This translates to "Pull up and out to remove the battery."
  • This does not translate to "battery is not removable"—as is written in English in the bottom right corner.
  • Despite inconsistent labeling, this battery should be consistently easy to remove with that pull tab—it's only lightly adhered in place. Here OnePlus decidedly one-ups its competition.
  • However, the battery falls behind its peers in capacity, with 12.70 Wh—slightly under the Galaxy S9+ (13.48 Wh) and Google Pixel 2 XL (13.6 Wh).
Sacamos un bonito soporte rojo para liberar ese largo cable de sensor de huella digital y espiamos la antena NFC de OnePlus destacada con tanta gracia.
Las antenas OnePlus anteriores funcionaban bien sin una parte trasera de cristal (que ni siquiera es para carga inalámbrica). Así que este cristal parece que es solo de vista y para romperse.
La lengüeta verde amigable en esta batería relativamente accesible dice "由此拉起可拆出电池". La traducción es "Levantar y sacar para remover la batería."
Esto no se traduce como "la batería no es extraíble" como está escrito en inglés en la esquina derecha inferior.
A pesar del etiquetado inconsistente, esta batería debería ser consistentemente fácil de remover con esa lengüeta, solo está ligeramente adherida en su lugar. Aquí OnePlus definitivamente le ganó a su competencia.
Sin embargo, la batería se queda atrás de sus pares en capacidad, con 12.70 Wh, ligeramente por debajo de la de Galaxy S9+ (13.48 Wh) y Google Pixel 2 XL (13.6).
