Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 34 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Gently pull the glass panel straight up off the iMac.
  • Gently pull the glass panel straight up off the iMac.
  • The glass panel has several positioning pins around its perimeter. To avoid shearing these pins off the glass panel, be sure to only pull straight up during removal.
  • Be meticulous about cleaning the LCD and the inside face of the glass panel before reinstallation, as any fingerprints or dust trapped inside will be annoyingly visible when the display is on.
  • When replacing the glass, be sure there's nothing between the glass and the frame. Stray cables could be damaged or crack the glass.
Insertar traducción aquí
