Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 3
Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside. Do not try to remove the display panel completely as it is still connected to the rest of the device. While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
  • Place your hands on either side of the bottom of the display panel, and lift it up enough that you can reach the connectors inside.
  • Do not try to remove the display panel completely as it is still connected to the rest of the device.
  • While holding the display panel up with one hand, locate and remove the display thermal sensor cable from its connector.
Insertar traducción aquí
