Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 4
As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display. Pull off the glass panel using the suction cup. Carefully disconnect the ribbon connecting the display assembly to the motherboard.  You can disconnect this ribbon from either end.
  • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
  • Pull off the glass panel using the suction cup.
  • Carefully disconnect the ribbon connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
Insertar traducción aquí
