Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 16
Paso 16
iPod Nano 7th Generation Repairability: 5 out of 10 (10 is easiest to repair). An easy-to-open case only requires unscrewing two screws and a plastic opening tool.
  • iPod Nano 7th Generation Repairability: 5 out of 10 (10 is easiest to repair).
  • An easy-to-open case only requires unscrewing two screws and a plastic opening tool.
  • Only standard Phillips #00 screws are used—no security or pentalobe.
  • The LCD and digitizer glass are not fused together, allowing replacement of either component separately.
  • "External" screws hidden behind the antenna mean less adhesive holding down the display assembly.
  • The battery, Lightning connector, button cable, and headphone jack are all soldered to the logic board.
  • The battery is adhered to the back of the display assembly.
Insertar traducción aquí
