Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 5
Peel the backing off of the adhesive back of the small temperature sensor board. Adhere the temperature sensor board to an exposed, metal area of the surface of the SSD, as close as possible to the SATA connector. Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  • Peel the backing off of the adhesive back of the small temperature sensor board.
  • Adhere the temperature sensor board to an exposed, metal area of the surface of the SSD, as close as possible to the SATA connector.
  • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
Pela la cobertura adhesiva de la pequeña placa del sensor de temperatura.
Pega la placa del sensor de temperatura a una zona metálica expuesta del SSD (lo más cerca posible del conector SATA).
Dobla el exceso de cable del sensor de temperatura para que no estorbe mientras terminas de instalar la carcasa.
