Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 4
Plug the included sensor-enabled SATA power cable into the wide side of the enclosure's SATA connector. The cable is keyed to connect in only one way. If you can't connect the cable, rotate it 180°, and try again.
  • Plug the included sensor-enabled SATA power cable into the wide side of the enclosure's SATA connector.
  • The cable is keyed to connect in only one way. If you can't connect the cable, rotate it 180°, and try again.
Insertar traducción aquí
