Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Line up the small SATA connectors so that the narrow side of the connector on the SSD matches the narrow side on the enclosure connector. Slide the drive in through the front of the enclosure until the SATA connector is fully seated. The SSD connects  with the enclosure in only one way. If the connectors are not lining up, rotate the SSD and try again.
  • Line up the small SATA connectors so that the narrow side of the connector on the SSD matches the narrow side on the enclosure connector.
  • Slide the drive in through the front of the enclosure until the SATA connector is fully seated.
  • The SSD connects with the enclosure in only one way. If the connectors are not lining up, rotate the SSD and try again.
Insertar traducción aquí
