Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 153 guías que incluyen este paso.
Traduciendo paso 13
Paso 13
Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
[* icon_caution] This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly. |
[* icon_note] Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass. |
[* black] Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna. |
