Saltar al contenido principal
Inglés
Español
Paso 11
Insert the point of a spudger under the loudspeaker flex cable and pry gently to loosen it from the frame. During reinstallation, make sure that the loudspeaker flex cable is properly seated using the alignment notches. If it is not properly aligned, the loudspeaker will not work.
  • Insert the point of a spudger under the loudspeaker flex cable and pry gently to loosen it from the frame.
  • During reinstallation, make sure that the loudspeaker flex cable is properly seated using the alignment notches. If it is not properly aligned, the loudspeaker will not work.
Insertar traducción aquí
