Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 22
Use the tip of a spudger to gently pry up the edge of the metal shield covering the battery level indicator cable. The metal shield is lightly adhered to the upper case and shouldn't require a lot of force.
  • Use the tip of a spudger to gently pry up the edge of the metal shield covering the battery level indicator cable.
  • The metal shield is lightly adhered to the upper case and shouldn't require a lot of force.
  • This metal shield may need to be transferred to your new part.
  • Be careful not to damage the battery level indicator cable while prying.
Insertar traducción aquí
