Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 10
Paso 10
That's it! In a surprising departure from its older sibling, this Pebble 2 turned out to not be very repairable at all. If we had the authority of the iFixit team behind us, we would probably rate this at a 2/10.
  • That's it! In a surprising departure from its older sibling, this Pebble 2 turned out to not be very repairable at all.
  • If we had the authority of the iFixit team behind us, we would probably rate this at a 2/10.
  • Pebble stuck with industry-standard 22 mm watchbands, so you can still swap those out all you like!
  • The motherboard and first part of the screen can be removed fairly easily,
  • but with both the battery and the vibration motor soldered on, there won't be much swapping going on.
  • Since the second half of the screen is glued to the front glass, neither it nor the glass are feasibly replaceable.
  • Button replacements are also a no-go.
  • If you're looking to stay on the Pebble train as long as possible, you might want to pick up a few of these on Amazon while they're still around.
Insertar traducción aquí
