Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 2
Carefully peel the battery warning label rounded end (the one without glue) off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
  • Carefully peel the battery warning label rounded end (the one without glue) off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
  • Remove the last 7.4 mm Y0 Tri-point screw securing the battery to the upper case.
  • Do not remove the label from the battery.
Con cuidado despega la etiqueta de advertencia de la batería de la caja superior entre la batería y la unidad de disco óptico para revelar un tornillo de tres puntos adicional.
Remueve el último tornillo de tres puntos Y0 de 7.4 mm que sujeta la batería a la caja superior.
No remuevas la etiqueta de la batería.
[* black] Carefully peel the battery warning label rounded end (the one without glue) off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
[* red] Remove the last 7.4 mm Y0 Tri-point screw securing the battery to the upper case.
[* icon_caution] Do not remove the label from the battery.
