Saltar al contenido principal
Inglés
Español
Paso 2
After removing the screws, your card should angle upward making for an easier removal. Using both hands, gently lift the card out of its socket in the direction away from yourself. Use caution when removing the card, bending the pins will damage the socket and your ability to reuse the memory card if you plan to.
  • After removing the screws, your card should angle upward making for an easier removal.
  • Using both hands, gently lift the card out of its socket in the direction away from yourself.
  • Use caution when removing the card, bending the pins will damage the socket and your ability to reuse the memory card if you plan to.
Insertar traducción aquí
