Saltar al contenido principal
Inglés
Español
Traduciendo paso 5
Paso 5
Remove the LCD paneland lay it flat on the keyboard. You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector. Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad  to see the metal connector underneath.
Remove the LCD Connector
  • Remove the LCD paneland lay it flat on the keyboard.
  • You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector.
  • Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad to see the metal connector underneath.
  • Using a spudger, lift the front of the connector up (highlighted by the white arrow).
  • Pull the cable back to release the cable from the connector.
  • To reassemble, follow the steps in reverse.
Insertar traducción aquí
