Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Rotate the laptop so that now the hinge is facing away from you. Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop. Slide the bottom panel towards you until it stops, and then carefully lift it off.
  • Rotate the laptop so that now the hinge is facing away from you.
  • Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
  • Slide the bottom panel towards you until it stops, and then carefully lift it off.
Insertar traducción aquí
