Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 13 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 7
Paso 7
Lift the internal frame off the bottom housing, starting at the rear edge, until you feel the concealed edge connector on the motherboard disconnect. Then lift straight off, minding the bluetooth and 802.11 antenna cables.
  • Lift the internal frame off the bottom housing, starting at the rear edge, until you feel the concealed edge connector on the motherboard disconnect. Then lift straight off, minding the bluetooth and 802.11 antenna cables.
  • When reassembling, the wifi antenna wire routes to the inside of the vent and then over the top of the vent.
Insertar traducción aquí
