Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Slide the spudger down the left side of the cover to loosen the clips. After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands. When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  • Slide the spudger down the left side of the cover to loosen the clips.
  • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
  • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
Insertar traducción aquí
