Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 6
Remove the static tape covering the two connectors. Use a spudger to disconnect the battery cables from the motherboard. If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  • Remove the static tape covering the two connectors.
  • Use a spudger to disconnect the battery cables from the motherboard.
  • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
Insertar traducción aquí
