Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Paso 4
Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board. To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery. Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
  • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
  • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
  • Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
Insertar traducción aquí
