Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Paso 3
Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end. Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
  • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
  • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Be gentle and keep an eye on the LCD cables as you flip the display over.
  • Lay the LCD on its face to allow access to the display cables.
  • Set the LCD down on a soft, clean, lint-free surface.
Insertar traducción aquí
