Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Paso 3
Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end. Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife. Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
  • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
  • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
  • Be gentle and keep an eye on the LCD cables as you flip the display over.
  • Lay the LCD on its face to allow access to the display cables.
  • Set the LCD down on a soft, clean, lint-free surface.
No intentes remover completamente el LCD del iPad, este sigue conectado por varios cables en la parte del botón inicio. levanta solamente de la cámara frontal.
Usa la punta plana de un spudger para levantar el LCD de su lugar y poderla sostener con los dedos. Puede que haya pegamento alrededor de los agujeros de los tornillos que se tenga que cortar con un cuchillo
Gira el LCD levantando desde la cámara frontal hasta el botón inicio como si fuese un libro.
Se gentil y observa los cables del LCD mientras giras la pantalla.
Pon la pantalla sobre su cara para permitir el acceso a los cables.
Pon el LCD en una superficie limpia y suave para evitar daños.
