Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Traduciendo paso 10
Paso 10
Remove the following screws securing the logic board to the rear case:
Two 2.3 mm Phillips screws
Two 2.7 mm standoff screws
One non-magnetic 2.7 mm standoff screw
[* black] Remove the following screws securing the logic board to the rear case: |
[* red] Two 2.3 mm Phillips screws |
[* orange] Two 2.7 mm standoff screws |
[* icon_note] Standoff screws are best removed using |
[* icon_caution] In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components. |
[* yellow] One non-magnetic 2.7 mm standoff screw |
[* icon_note] Be sure to put this screw back in its original position at the top of the logic board. A magnetized screw may interfere with the digital compass. |
